Raspy Sound From Down Pipe!
I got the rrm down pipe and now my car sounds like a raspy civic! I already have a greedy axle back and don't wan't to go with a resinator because of restrictive flow. Does any one know if I finish it from down pipe to axle back with a larger pipe would it sound better? Or should I go with a whole new cat back system.
Speaking from experience.....the resonator does less for sound than the high flow. I started by adding a resonator and the real results came with the CAT. The 2.4 is a very difficult beast to tame. I spent about $1200 and still had a loud car. Do it right the first time. I had a 2.25" cat back made with the RRM dp. The more the 2.4 flows, the louder it gets.
Yeah i like the loudness just not the raspy sound! I would like it just as loud but deeper and not like a civic with a CAI and a 3" cat back with a 20" tip! So I am not trying to queit the beast but obtain a deeper cleaner sound! What ideas do you guyz have for me?
The loudness doesn't bother me too much or even the fumes. What really bothers me is the axleback from RRM, I guess it can't handle the flow or what but between 2000-3000 RPM I get this horrible vibrating/buzzing "cheap ebay muffler sound"
"bee in a can"
Will a high flow cat and resonator actually take care of this? Or should I start looking for a better muffler? Ie. something more expensive ?
I'm considering just going back to stock
"bee in a can"
My car is set up like this:
CAI--->downpipe--->24" resonator--->axleback
The resonator and the axleback are both Magnaflow. Without the resonator I couldn't stand the sound! It was both loud and raspy (as someone else mentioned). That resonator cut the sound probably in half, and got rid of MOST of the raspiness. I still get it when my car is cold, but usually disappears after a few minutes of driving around. This is probably the best sound you are going to get without putting in a CAT.
For anyone doubting the resonator, trust me on this. It is still very aftermarket sounding, and the neighbors still know when I'm home! When you blip the throttle, it gives that little growl when pulling up... a real head turner.
Originally Posted by jvallier
is someone going to defend the comment Adam makes about RRM muffler sounding like a 'beein a can'...i kind of want one, but i don't like that feedback about the muffler.
Originally Posted by psychlancer
Anyone know what the sound would be like with a stock muffler, and the RRM downpipe? I'm not sure if anyone has this set up, but I was thinking of trying it in the spring.
