Accolade body kit install
I just ordered a body kit from accolade and i have few questions. I want to install it myself. Will it just match up with the holes. And do th side skirts do they use tape or what holds them up will i have to drill them
usually for side skirts you have to drill holes to hold them up and in place but they are the ones on the inside of the wheel arch and a couple on the underside of the car as for the rest you need to use Sikkaflex which you can buy from any car paint supply place you will also need to get a couple of smal but heavey drums to keep pressure up against the skirt till the glue has set but if you guys are having winter over there then the glue will take much longer to set so make sure the area that you are doing this in is reasonably warm
MikeyD
May 24, 2006 06:15 PM
