how do u change the auto shift knob?
hi i was wondering how do u change the automatic shift knob. i saw a knob that caught my eyes and i want try to install it myself. can some be kind enough to post a step by step on how to change the knob. thx you very much for your time the knob i saw was the RAZO prestige chrome.
I got this one installed on my Sportback RA.
From the diagram :
1) Remove the 2 sml bolts in the front on the OEM shifter.
2) After that you can pull the OEM shifter up.
3) You will end up with the AT shaft with a small plastic butom at the top.
That small white plastic thing at the top of the the shaft is the engage lock. When you install the Razo you have to make sure that the top cap have enough clearance to let the white buttom engage/dis-engage w/o problem. (and make sure that the Razo shifter allen bolts are tight enough...you can use 1 of 2 drops of blue lock-tite just in case). If the Razo shifter slides down just a little the car key release of the AT tranny won't work at all and it will be a real PITA to take out the key. (It happenned to me twice...keep the install allen key on hand).
It is a really easy mod to do and it would take only 10 to 15min max. I hope this will help you.
Naco
Dec 9, 2011 02:26 PM
