How do i put leds in my headlights?
I saw a lancer with leds in the headlights check out this link http://www.cardomain.com/ride/2606926 I think they might look even better on my black ra so i was wondering how would i go about doing this? is it as easy as buying the led strips and putting it in my headlights? if so what would be a good size 3inch 6inch 9inch or 12inch please
Last edited by BlackRalliart#1; Feb 1, 2010 at 04:57 PM. Reason: i forgot to add something
also found this http://www.cardomain.com/ride/3140499 i wanna know how to do!
im getting hids too i wana try the led strip with the hids i think my car can pull it off and still look clean i dont think audis are the only cars that can pull it off beamers can definately pull it off too and soon so will my car.If they dont look the way i expect i can just take them out the leds arent expensive at all i just need to know what size will fit perferctly in my headlights
if you guys are deadset on trying it all i can think of is just open up your headlight housing and get them there and wire them to go on with your headlights or you can have them set to activate when just your turn signals are on. but its really your call. HIDs would probably make it look best.
i'd say probably 6in or 9in depending on how much of the bottom of your headlight you want to cover. i havent taken exact measurements on how wide it is so its up to you
esoteric
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 6, 2015 07:29 AM
Curt@MrLed
Evo 'For Sale' Electronics / Lighting / Audio
147
Mar 28, 2011 09:47 PM
