Fog housing is broken
my passenger side fog housing is broken, probably knocked loose by a pebble or something. now at speed it wobbles back and forth and at night i can see my fog's beam moving back and forth.
i looked under the bumper and i can see that the top right piece of the housing has broken off with the screw still in it, along with the bottom center screw. i will put up pics if needed, but i just need to ask.
brand new fog housing or epoxy/jerry rig this one?
thanks in advance.
- NashvilleRA
thanks in advance.
- NashvilleRA
Last edited by nashvilleRA; Jun 23, 2010 at 01:43 PM. Reason: newfound problem: bottom center screw.
here are the pics. and the video i took, which would be helpful, does not work.
^^^i circled the fog light because i know it is cracked, and is not really the problem now. light output is just fine.
^^^yet another view of the cracked lens. the circled part is obviously broken and i dunno how i should fix.
^^^this is the "top" screw i mentioned. the cord/sheath you see is the fog light wiring, the left side of the picture is toward the middle of the car.
Heliart
15
Oct 2, 2023 02:33 AM
chlucero
Jan 11, 2011 07:50 AM
