Grill mesh and lower mesh both done
I took a large piece of paper and traced the shape of the inlet at the point it tuns into black plastic. Next I cut the mesh on a band saw to slightly larger than the trace. I then worked it carefully into place being careful not to scratch the paint (this took the longest). When in place I use long black zip ties around the plastic pieces inside to keep it in place. If done right the tention of the fact that he mesh is larger than the hole keeps it in place. Other than that you can cut it exactly to size and use glued on holders to keep it in place.
Mouse
Aug 18, 2004 04:04 PM
