Evo 8 Spoiler - Faux CF or Real CF?
Just curious guys,
I can get a good deal on an Evo 8 Wing, however, is the CF that comes with the real wing from Mitsubishi real or fake? I'd like to know prior to buying it for my cuz.
Thanks
Thanks
ok here we go again, if your were offerd $450 painted and installed, then it's FAKE!! and made of abs plastic with "look-a-like" carbon fibre, if they said $1800 for the wing installed then this is the real deal, cuz that's what they cost from the dealer in Canada, and they come already painted from Mitsu
Just because it is cheap doesn't mean it's not real carbon fiber. I got my wing for $225 and had it painted and installed for $75 and its real carbon fiber but its not an oem evo wing.
Here are some of the ways to see the difference between the real and fake, here are picutures of mine:
Real Carbon fibre has a very high gloss, you will see the fibre through the clear coat:
And also the Real wing will Have Rivets int the center of the side supports, the others will have them at the edges and they are screws,not rivets
There are aftermarket real CF Evo VIII wings available new for under $500, but the ones I've seen only have the center as real CF, and the side pieces are fiberglass or ABS, so still not as good as the real thing.
also to add what modernracer says, the part numbre on the OEM one is engraved on the bottom of the wing where it bolts to the trunk thats one way you can tell if you have the real deal or not, also on the RA's you have to drill holes to make it fit, The one i have is the EVO9 OEM wing, and it was pricey, over 2600 for the wing- paint and modify the trunk for install, and the center piece does not detach from the sides, its all one piece, soild..Don't think i'm knocking the aftermarket one cause i'm not, every one has their own personal tastes and of course buget's
