Evo side spats on Ralliart?
#32
The side skirt spats will not fit because the EVO's side skirts are taller (in terms of height and the curve is much more fluid unlike ours that is more angular). I know this very well because I want to fit the spats a year ago....
If you are thinking of fitting the EVO's side skirt onto your RA, first you need to modify some fitting points. Next its going to be sticking out quite afair bit because on the front and rear of the EVO, they have a wider body stance than the RA and the EVO's skirt follows the stance. I know this quite well as well because I wanted to fit either the Varis or the Damd sideskirt extension but the sizing and mounting points are all different......
#33
okay...when to the mod shop today and dished ou the Kansai side spat. Because its very thin CF, you can flex it to fit in almost perfectly. However it will not cover the whole rear side of the RA side skirt leaving about 1.5 to 2in of it uncovered.
If the one you are looking at is flexible enough to fit...I guess it would.
richardjh
21
Feb 3, 2015 09:38 PM
andrewRA
Jan 7, 2011 07:00 PM
