04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Boost rpm range
Old Aug 1, 2007 | 08:20 PM
brianday000's Avatar
Boost rpm range
Need to know what rpm range I can expect to be getting full boost on diff types of turbos so I can decide which I want to buy.
Anyone with turbo's, can u post up at what rpm you obtain full boost pressure.
I found a Garrett GT40 A/R .58 Compressor 82 mm wheel, Turbine A/R .89... haven't heard of anyone running this one on the RA. I think it would lag as most turbines that people have are between .6-.7 on the RA - but the compressor is smaller than avg... what effect will this have..?
It's BB so it should spool a bit faster than norm too but I need input.
Please de-noob me, so I can begin my parts build-up
Old Aug 1, 2007 | 08:29 PM
Evo's run gt40's and they're only 2.0l so a 2.4 should theoretically have enough flow for quick boost....?
This is one part of FI which flies right over my head...A/R's and wheel diameter stuff...is there a site which shows recommended turbo applications?
Old Aug 1, 2007 | 09:54 PM
nvm
http://www.turbobygarrett.com/turbob...ch_center.html
Old Aug 2, 2007 | 04:17 AM
chowetime's Avatar
I have a Garrett GT2537 = 370hp I am running about12psi and max boost is at 4250rpm
Old Aug 2, 2007 | 04:22 AM
MITVRX's Avatar
^ impressive!
Old Aug 2, 2007 | 11:11 AM
Kinga's Avatar
My JDM with stock turbo max boost is between 4200 and 4400 rpms
Old Aug 2, 2007 | 02:45 PM
reTro's Avatar
Well, I have the Mitsubishi BIG 16G (RRM kit) and it seems perfectly matched to our engines. Starts to boost around 3000rpms and hit's 7psi by 4000rpms. It's rated to 380hp.
flow: 550cfm
boost: 20+psi
Old Aug 2, 2007 | 06:00 PM
ski10804life's Avatar
I am runnin a t3/t4 and it start spooling around 2,800 and full boost soon after, turbo is good to over 400hp but i dont think i will ever get there with my RA nore would i want to with front wheel drive car hahaa
Old Aug 2, 2007 | 06:31 PM
otter's Avatar
EvoM Administrator
No way in hell you're going to efficiently run a GT40 on a Ralliart Not unless you intend to replace everything internally on the engine then crank the boost WAY up.
Old Aug 3, 2007 | 07:43 AM
Eclipse2Lancer's Avatar
+1 on that.
Not on stock internals and low boost.
Old Aug 3, 2007 | 09:28 AM
Talon's Avatar
[quote=brianday000;4600299]Evo's run gt40's and they're only 2.0l so a 2.4 should theoretically have enough flow for quick boost....?
[quote]
Ummm, are you serious? You want to put a GT40 on a Lancer?
Carloverx
15
Aug 5, 2009 05:20 PM
Strictly Modified
Jan 7, 2009 10:48 PM
discopotato03
Dec 27, 2006 03:59 PM
trinydex
Jun 3, 2006 11:39 PM
rt turbo
Apr 25, 2004 08:58 AM
Quick Reply: Boost rpm range
