06 ra dyno!!
06 ra dyno!!
Hey guys..
Tomorrow my lil red baby will hopefully be on the dyno at Lightspeed Innovations. Just curious if anyone is interested in taking part in the guessing game
MODS:
Stage 2 RRM big 16G turbo kit
Snow Performance Meth injection
Custom PnP Head
RRM PnP Intake manifold
RRM Camshaft
RRM UDP
Magnaflow Catless Catback exhaust
550CC injectors
ViPEC Standalone ECU
MODS:
Custom PnP Head
RRM Camshaft
RRM UDP
550CC injectors
Mustang dyno, i would say 240-260whp, depends how agressive your P&P head is, and what your doing with your meth injection.
thats awesome man.. goodluck on the dyno. thats always an exciting day. Dont forget to post up the numbers and everything...
reading your sig, it says you have the RRM turbo kit and 550cc injectors. I'm guessing your ditched the 5th fuel injector and using 4 large ones? And how do you like that ViPEC stand alone? like it? easy to tune and use with our setup?
thanks and good luck on the dyno remember its a mustang dyno so you wont be hitting huge power. dont get depressed when it only says 240whp, cuz that 240 whp is probably 290 on a dynojet.
she's going on a dynopack.
should see same numbers as a mustang dyno.
i'm hoping for 250whp, anything after that is a bonus.
my tuner says vipec is a very reliable and easy standalone to tune. i did forget the rj45 to serial connector... wideban to ecu ? if that makes sense. so narrowband will be off.
great news...some of it bad...
well, today she went for a hard pull ... at 3000rpm... full boost...it blew the clutch.. ahahaa
the tuner said he saw it spike to 300ft/lb tq before to let off on it.. when he was idling it before the clutch would slip, it was producing 268 ft/lbs at around..2700?
should be interesting.
new clutch/flywheel going on
edit:
that was without the meth injection.
edit:
