04-06 Ralliart Engine/Drivetrain (no forced induction)
Cylinder Head project !!!
Old May 2, 2007, 08:27 AM
  #46
migueralliart's Avatar
OK so the cyl head is at the porting machine shop and the cam has been sent to regrinding !!!
Old May 2, 2007, 03:08 PM
  #47
MITVRX's Avatar
woohoo! off to work migue, talk soon!
Old May 2, 2007, 03:43 PM
  #48
ralliart329's Avatar
Awesome Migue!
Old May 2, 2007, 06:27 PM
  #49
DangerousDan's Avatar
pics work at home. That looks like alot of work, how long did it take to disassemble everything? That's quite a big difference on the exhaust side, sounds like there is lot's of room for improvement. Can't wait to see your results, this will be great.
Old May 2, 2007, 06:31 PM
  #50
Valve train took me half hour to disassemble without the mitsubishi special tool heheh but it's worth it , head is in work now by a friend and I think I will receive it by this next Wednesday ... Camshaft is being regrinded and in a few days I will start a new thread on the benefits of a lightened stock flywheel versus the aluminum one .... COMING SOON hehehehe
Old May 2, 2007, 07:40 PM
  #51
MITVRX's Avatar
Let us know how the regrind goes, what lobes are you modifying? Agressive or mild?
Old May 2, 2007, 07:52 PM
  #52
There are only three lobes the one in the middle is the one that I want to modify cause it's the high lobe the other side ones are the low lobes which have different lifts, they keep one valve open with the most lift and the other valve semi open (less lift) so that low end torque remains. mitsubishi did a good research, when they tried not to activate the mivec they found that the point in which torque decreased was in the 3500rpms so theres when they applied the high lobe , THE HIGH LOBE is the only one that should be modified , if you have CAI PORTED HEAD AND INTAKE MANIFOLD you definitively need to only touch the HIGH lobe not the secondary lobes only the HIGH lobe the one in the middle . If you touch the other two you will have weird idle problems
Old May 2, 2007, 08:04 PM
  #53
MITVRX's Avatar
I'm getting a camshaft done, and the lobes that will be modified will be from mivec onwards, high lobes.
Primary lobes won't be touched.
You doing an aggressive profile?
Old May 2, 2007, 08:16 PM
  #54
Yep I need a little more overlapping cause my engine will move a crazy AMOUNT of air once past 3500 because of the porting and the intake
Old May 2, 2007, 08:41 PM
  #55
MITVRX's Avatar
Sweet as, 250whp N/A here we come!
Old May 2, 2007, 08:46 PM
  #56
Yeahh man that's the goal I know we can do it
Old May 2, 2007, 09:05 PM
  #57
PR_Mivec's Avatar
im sure you will
Old May 2, 2007, 10:30 PM
  #58
Henrys Ralliart's Avatar
DANG MANG! sweet stuff. Way to pioneer!
Old May 2, 2007, 10:49 PM
  #59
MITVRX's Avatar
Originally Posted by pr_mivec
im sure you will
Was that sarcasm or ..?
You can never tell on the internet these days. I think "im sureeeeeeeeee you will" or "im 'sure' you will'" falls in the category.
Okay anyway, back on topic!
Old May 2, 2007, 11:33 PM
  #60
where/how did intake manifold gasket come from
Quick Reply: Cylinder Head project !!!
