04-06 Ralliart Engine/Drivetrain (no forced induction)
RA firing order same as EVO?
Old Oct 16, 2007 | 07:49 PM
LithiumX's Avatar
is the RA cylinder firing order the same as evo and do we also fire 2 at a time i think evo is 1,3-2,4 (2 at a time) just curious for now
thanks and sorry if i missed somethign in searching ....
Old Oct 16, 2007 | 11:36 PM
stEVOx's Avatar
i think so, ive seen something like this on youtube but cannot find it
but arnt most 4cyl be the same
1 and 4. 2 and 3 move at the same time
1 and 3, 2 and 4 fire at the same time
Old Oct 16, 2007 | 11:42 PM
JohnnyBoy427's Avatar
OO idk if all 4 bangers are the same because mine STATES they go individually. I dont remember the exact order though.
Old Oct 16, 2007 | 11:50 PM
joeyj's Avatar
its 1-3-4-2 same as the 4g94
here is link for ya, if you need any other ignition sequences, just let me know!
http://i223.photobucket.com/albums/d...e/DSCF3203.jpg
and other mitsu engines as well
http://i223.photobucket.com/albums/d...e/DSCF3204.jpg
Old Oct 17, 2007 | 12:22 AM
LithiumX's Avatar
thx got the one for 4g63t post 04 by any chance ?
Old Oct 17, 2007 | 01:25 AM
joeyj's Avatar
stats i got for 04 evo engine:
hp 271@6500
tq 273@3500
bore x stroke (in.) 3.35x3.46
compression ratio 8.8:1
oil pressure 43-100@3500
spark plug gaps (in.) .024-.027
fuel pump (psi) 38
my stats indicate that all 4 cyl mitsubishi engines years 01-04 (4g15, 4g93, 4g94, 4g64, 4g69, 4g63) all fire in 1-3-4-2 sequence
whereas all the 6 cyl engines from those years (6g72, 6g74, 6g75) fire in 1-2-3-4-5-6
all sequences are the same for both AT and MT where applicable
so yes 4g63T fires in 1-3-4-2
hope this helps!
Old Oct 17, 2007 | 05:27 AM
DangerousDan's Avatar
coil packs=fire individually right? never would have though coil packs fire any other way...
Old Oct 17, 2007 | 12:41 PM
LithiumX's Avatar
thx, not sure about the coil pack issue though, i remember reading they are individual fires but simultaneous but i may be completely off now
Old Oct 17, 2007 | 12:50 PM
they use multiple firing to keep costs down, individual coil packs would negate the cost. the more I think about it... each coil is controlled by the ecu individually, so I doubt they fire at the same time.
Old Oct 17, 2007 | 01:29 PM
joeyj's Avatar
yeah, each engine, whether the ignition system is distributor-less with or without a coil-on-plug system doesnt change the firing order
i.e. 4g64 with DIS and 4g69
even the 4g64 without DIS fired 1-3-4-2
moyassine
Feb 21, 2016 11:54 AM
SPOOLIGAN
11
Feb 15, 2016 09:51 AM
Balrok
Dec 18, 2015 10:43 PM
joey12
Jul 30, 2009 01:47 AM
kimletrim
May 5, 2008 11:42 PM
