Aem F/ic
RRE makes one that works with the 4g eclipse which has CANbus connection and DClipse is using this setup at the moment. Also the FIC-8 is much cheaper than the RRM turbo piggy and it works with a variable signal MAF.
Which FIC are you using. Both -6 and -8 work but the -6 needs to be messed around with thte MAP and so on and its not that "reliable" imo
CANBus has nothing to do with the FIC...it doesn't interact with it in any way. The FIC-8 works the same way the -6 does, it just adds two injector channels and support frequency manipulation for frequency based MAF's, but like I said, you don't need that anyway. It has some other new features too, but the -6 would work as well...
Brian
Sicktght311
Lancer Aftermarket Forced Induction Tech
42
Mar 30, 2018 01:13 AM
Richard L
149
Feb 27, 2016 03:01 PM
4WS Tuning
29
Jul 16, 2008 10:34 PM
HiVoltEVO8
49
May 11, 2006 11:50 AM
