Finally found how to install a SAFC on a Ralliart
![Thumbs up](https://www.evolutionm.net/forums/images/icons/icon14.gif)
Yes guys, it is possible (with a little work); an it is not being connected to the map sensor (it does nothing that way - I've tried it too). Im using this setup with de maf sensor for about 2 months now with no problem...
First, thanks to Dangerous Dan for the tips he posted that lead me to the solve of the mistery.
What is happeing here is a load incompability between the ecu and the apex unit; meaning that the ralliA ecu has a 1k ohm internal resistance that is not very compatible with the safc. How to do the intstall:
First let me clarify that ralliA maf IS a hot wire type.
1) Install a 1k ohm resistor between the maf signal and ground so that the maf "sees" that load if you dont it will send 5-7volts to the safc. Do it between the black and the white cables of the safc.
2) Now, the safc doest not have enough power to cope with the ecu resistance so you need to raise the power of the apex output. I used an LM358 operational amplifier configured as a voltage follower so it mantains the voltage but gives more power (current), I used the LM358 because it can be operated with positive and ground voltages (not dual power), becuase it is very chap (less than one dollar - at lest in mexico), and because you can find it in any electronic equipment store. Connect number 8 pin to swtiched 12 volts (safc red cable), pin 4 to ground (black cable), pin 3 to the safc output signal (yellow wire) and finally to make the voltage follower join pins 1 & 2, this last will be your signal output to the ecu (pin 64).
Do not solder directly to the opan or you will fry it; use a base to solder the wires, and the plug the chip to it.
3) Configure the safc as sensor type: hot wire, sensor No. 3 - 3 & sensor cal 1 - 1.
Use APEX wiring diagram M7-a.
This really works I tested the results with my wideband, and now I can really control my air/fuel ratio!!
If you are buying a new piggy back for your ralliA I would recomend to go for a rrm but if you aready have a apex or found a bargan used one (like me) it is worth the trying.
by the way the link to the LM358 datasheet: http://www.datasheetcatalog.org/data...r/DS007787.PDF
All other lm358 conections are refered to the apex wiring, thought it would be a little easier to understand thay way..
Any way, give me a couple of days to make a diagram so it's easier to undersand..
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
k thanks ya i read it slower it made more sence but i cant seem to find the lm358 with out an m or an n or somthing on the end of it
do you have a link to a website that would have it cause the ppl at radio shack or dumb.
Edit : if its not to much trouble c an you take picutres and define them.
any of the lm358 series should work, the difference comes on the housing, pin form and some voltage and current characteristics. I think I'm actually using a lm358n......if tomorrow I get home early (while there is still light) I'll take the pictures.
Here is a photo as you can see it is "encapsulated" with tape...
You can also find a diagram. Hope this makes things easier.
Remember do no solder directly to the lm pins you will fry it, use a base.
If you have a good (not mine) and are handy enough (no me
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
Thanks Dan! I was a LOT of work..
About the tune, well I removed the turbo 'cause my custom manifold craked, so I will re make it and get bigger inyectors...but that will have to wait a while; I'm running a little low on cash right now
So now that is NA again (hopfully not for long) it really helps i didnt think it would change that much with only this... the car is bone stock except for the SAFC. Im aiming for a 12.8 afr at wot; before the mivec switch I'm adding between fuel after that Im decreasing a little.
tboboy
Aug 7, 2010 03:39 PM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
43
Sep 14, 2008 05:58 PM
Stripper
28
Aug 18, 2007 02:15 PM
