Ignition Coil Upgrade.....
I found on the internet a brand SparkTech that makes coil on plugs for evo 8, Is there a way to fit these on our cars even if we have to cut and connect certain wires ourself?
10,000 - 20,000 more volts it said something like that. I'm not sure if our coils give out the same voltage as the evo coils but I would think so, as long as it's more power, make sure to burn all that fuel.
I don't really know what the output is for the evos. Considering that the evo 8's use plug wires i would be guessing about 60-80K secondary voltage. So you are saying these are above 80k? No need for even slightly modded cars unless you are running high compression or a high amount of boost.
well it showed a picture with coil on plugs on the evo even though every evo I've seen had plug wires. As long as it's just alittle over our stock coil output it would be a nice upgrade, not that it's needed but if you choose to.
thats true, that just sucks that there is no ignition parts for the ralliart out there. maybe open the coil plug and switch it out something extreme like that.
our coils suck! if they get humid they fail...here in pr theyr a problem....our solution is to switch to Corvette coil on plug system where it's 4 lil coils(box type) with a cable going till the sparkplug.
WTB[MidWest]: Coil cover
murderedout
Feb 26, 2016 02:59 AM
gixxer750
Mar 22, 2011 07:53 PM
