Engine Light On After Intake
So when the injen CAI was installed on my car everything was fine. Then one day I decided to go through an automatic car wash, with an undercar wash. I came out of the car wash fine, and then went home for a bit. A few hours later I went for another ride to school and going up a hill pushed my car a bit hard... then suddently my car was struggling to get past 4000 RPM and then the engine light comes on...
After a few days it seems the car drives fine, but the light is still on... and ideas of how to fix this? Or the problem? I thought maybe just a bit of water got in... but its been 2 days now, and the light is still on.
Former Vendor
Water got into something, and caused a misfire. Ecu picked it up. Shouldn't have anymore problems so long as you don't get water into whatever caused the issue. You should only mist the engine bay, not direct pressure.
I did that once I got home from the garage, after resetting the ECU the engine light is off... however does this mean that the light isn't on but there still is a misfire?
