need help? 4G63T head swap for my 4g69!!!
![Exclamation](https://www.evolutionm.net/forums/images/icons/icon4.gif)
i have some questions for upgrading my engine?
- can the 4G63T evo 9 cylinder head fit my 4g69?
- do i need evo wiring and ecu?
-can i swap my brakes to evo 7/8/9 brakes front/ rear
- can i swap my speedometer dash board to evo speedometer dashboard
so please help me because iam in progress of building my engine :-)
![EvoM Super Moderator](http://forums.evolutionm.net/images/titles/supermod.gif)
Ok let's see here , yes the evo head will fit there's lots of them swapped and running in puerto rico you'd get alot more help on that subject if you can find a pr based forum , how's your Spanish?
As for the ecu etc. It would be a bit easier to do a standalone but not extremely easy by any means either way. The front brembos will fit with evo hubs from what I understand. You'll have to get some larger rims as well, with the correct offset as to not hit the brakes.As for the rears they bolt right up. And yes the evo cluster will plug and play. BUT keep in mind all of this is based on the US model I'm not 100% sure that it's still the same for you over there. Got any pics of your car?? Hope this is helpful..
regarding the engine yes it will be the american version. i was thinking of fitting the evo 8 head non mivec engine, easier in assembling.i will get the evo 8 wiring and ecu.
so the front and rear brakes fit. allready i have 17" offset 45 so i believe that fits.
thank you very much for your help
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Hey man I said the front will fit WITH the evo hubs/knuckles they won't bolt up , as for the 45 offset fitting I highly doubt it , I'd say get some 5,8, or 10 mm spacers then it should work for you. But unless your pushing the car real hard I don't see the need , you should but the cash somewhere else. Upgrade the rotors(oem size), pads, and stainless steel brakelines. But it's up to you.
![EvoM Administrator](http://forums.evolutionm.net/images/titles/admin.gif)
Hey man I said the front will fit WITH the evo hubs they won't bolt up , as for the 45 offset fitting I highly doubt it , I'd say get some 5,8, or 10 mm spacers then it should work for you. But unless your pushing the car real hard I don't see the need , you should but the cash somewhere else. Upgrade the rotors(oem size), pads, and stainless steel brakelines. But it's up to you.
About ECU and wiring, you can do this Lancer RA reflash ... in a different way
Its cheaper than a full stand alone and you can do the same
This all can be done with at least 17" rims and maybe some 8-10mm spacers.
This is interesting because i have always wished to see an RA with brembos.
Please correct me if im wrong.
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
ive also looked into this head swap....does anyone have or know of any dyno numbers n/a or boosted???
would it be worth the time and money..if so..how much hp we talkin???
I'm also looking to do this , I know it's been done before but I'd like some one to shine some light the topic.
A full parts list would be a great start!!!
So if someone know more about it or has done it plz PM!!!!
Ok do you readily have 3k to spend on this ? Not to be rude but alot of people have these "great ideas" but rarely do people ever even attempt to follow through. So basically researching an itemized list for someone elses project is only a job for the very bored. But on the other hand if you were to start a list of what have show your journey to it you'll most likely get alot the help/tips your looking for. Just saying.
4G63_EVO
Jul 8, 2017 02:19 PM
senate6268
128
Sep 3, 2015 10:44 PM
Kasper
Feb 19, 2015 11:48 AM
4G63_EVO
Dec 23, 2013 08:51 PM
