04-06 Ralliart Engine/Drivetrain (no forced induction)
Tranny gone
Old May 3, 2011, 04:10 PM
GearDownSon's Avatar
Tranny gone
Well it finally happened. I wasnt even driving hard.
Was behind a school bus an i took off in 1st then when i went to put it in 2nd it wouldn't go. I limp the car to work an it wont go into 2nd even if the car is off. Reverse is acting funny too. If i have it in neutral an let off the clutch the car lurches just a bit. Sucks
Old May 3, 2011, 04:59 PM
EvoM Super Moderator
lanzerralliart's Avatar
Damn bro that sucks , you hadn't ever changed the tranny fluid right? Maybe waiting til 100k wasn't so good?
Old May 3, 2011, 05:15 PM
nerdbotSKRA's Avatar
*Plugs ears* lalalala
That sucks man.. what's the plan now ?
Old May 3, 2011, 05:37 PM
I changed it when i did the turbo
Found one with 46k miles at a salvage yard. 800bones
Old May 3, 2011, 07:20 PM
rdc
rdc's Avatar
So even though you'll get a new tranny, do you have any plans to open the broken one to see the carnage (and maybe get some info as to other gears that may be swappable or even beefier parts like synchros, etc.)? I've always wondered if it were possible to convert our trannies into 6sp for that overdrive gear.
Old May 3, 2011, 11:32 PM
$MIVEC$'s Avatar
Well in PR many people do "trick out" their tranny with mirage ls tranny's. Also ive read here that some people have experimented with making the RA a 6speed but as far as I know only the evo MR has the 6speed tranny and its not exchangeable.
Maybe we can exchange the final gear with some other tranny?
Old May 4, 2011, 12:30 AM
mmoulton470's Avatar
That sucks man, sorry to hear it. Good luck from this point forward.
Old May 4, 2011, 04:48 AM
I may open it. idk. I have a pretty good idea of what i would prob see. Car has been boosted over 3 years so i didnt exactly expect it to hold out forever. Tbh im surprised it held out as long as it did.
Old May 4, 2011, 08:03 AM
CrAnSwIcK's Avatar
sorry to hear that, but 800 bones is not a terrible price, it would be worth while to open it up, as there is not much to it...i would say a 6th gear would not work as the tranny is not designed for it, but a larger 5th gear would be interesting...
Old May 4, 2011, 10:15 AM
Ralliart_on_LSD's Avatar
Thats what you get for "granny shifting. Not double clutching like you should".
Old May 4, 2011, 03:41 PM
I never had my car.
Old May 4, 2011, 05:47 PM
CrAnSwIcK's Avatar
if double clutching was so cool, they wouldn't have invented synchros LOL!
i granny shift, it's OK, you're not alone...
so crack your tranny open already, i'm curious as to what the problem is, if it's a relatively simple fix, you can rebuild the tranny for cheap and sell it to recover some funds...it'll be a good learning experience anyway...
for myself, it's my first time inside a transmission, pretty wild looking, but fairly simple when it comes down to it, everything in there has a part number, and if it's broke it should be pretty obvious...
Old May 4, 2011, 06:06 PM
rdc
rdc's Avatar
Do you mean the tranny won't bolt up to the engine or the internals just don't fit or both? What are they using from the mirage, the synchros?
Old May 4, 2011, 06:11 PM
Going to get it on sat. Installing on sun
Old May 4, 2011, 07:04 PM
$MIVEC$'s Avatar
From the 6speed thing I dont have enough info but im almost sure the evo tranny wont fit.
From the mirage LS I got a friend that put some gear parts to his RA tranny. Also the LS tranny fits on the RA with a modification for it to bolt on....so maybe it works the other way around.
Le metio piņoneria de tek....creo que le cambio la tercera pa ayudar.
Quick Reply: Tranny gone
