p0183 fuel temperature sensor a circuit high input
ok i have a 2004 lancer ralliart my gas has been acting up on me i would put gas and it go to full once it would reach haft tank it would just drope to empty so i took off the fuel pump and clean everything no it work ok but im getting the error if i check with the obd2 (P0183 FUEL TEMPERATURE SENSOR A CIRCUIT HIGH INPUT) how can i fix this ???
Do you have any diagram for the part or picture .... This part is located bellow the back seat right????? Do you recommend to check or just to order the new part but i had the problem for a while already
P0183 FUEL TEMPERATURE SENSOR A CIRCUIT HIGH INPUT...........this is the error im getting ... i went to order the part from a Mitsubishi dealer but i just want to make sure when i put the part # u told me it saids (gauge unit ) thats the one i need right ..... thank you so much for your help
Boost3dxEvO
Aug 21, 2009 06:23 PM
BadazzCR
Aug 23, 2008 07:40 AM
circuit, cost, endeavor, engine, fuel, high, input, mitisubishi, mitsubishi, p0183, pump, sensor, sonata, temp, temperature
