What oil is the best?
#31
I'm no expert, but i would say putting gear oil in an automatic trans would be a bad idea. I would imagine it would work, but i'm not exactly sure how the pump, and torque converter would handle a heavier fluid. Plus for automatic, you need a shiytload more oil than a manual, might get expensive if you wanted to use high end gear oil. ATF and an oil cooler would probably bee your best bet.
Take the fill plug out, it's a bolt on the front of the transmission case, and it says "oil" on it. If you pull that out and fluid comes out, it's full, if not stick your baby finger in the hole, the fluid level should be at the bottom of the hole, if it's not it's low...i actually overfilled mine slightly, a friend of mine does that so i tried it out. Take a fluid sample, to see what it looks/feels like, if it's dirty, replace it through the same hole, the drain plug is on the differential case.
#33
Who was the guy that was turbo and auto? i think it was one of the PR guys, i don't remember who it is, but i think he had installed one...i'm sure there's kits and half-arsed instructions somewhere on the net. I can't see it being too difficult.
#34
If you need more help PM me or call me 786-236-0966.
#35
Just follow the recommended intervals in the owner's manual. I believe the suggested regular interval is 7500 miles.
#36
I'm at like 94.5k right now. In the manual it says I need one at 97k I believe? But Otter, I have a question, my oil light keeps coming on when I idle. But my oil is fine, I checked it and it's brand new oil. They put it in right before I bought the car. Do I have a bad sensor or something?
#38
#42
Keith you can buy that from Rock Auto for about 5 buckx plus shipping. The sensor is located at the back of the block. It's a little tricky to get at, I used like a 23mm socket to get it out.
#45
you disconnect the wire harness, unscrew it and screw the new one in, it's really simple...
The reason i mentioned the NPT vs BSPT thing is that if the aftermarket sending unit has NPT threads, you'll need an adapter.
