What oil is the best?
While I agree with Dacib (I personally use royal purple) but everyone is going to say what they use is the best. You should look into what your needs and driving characteristics are , then research on an oil that will give you what your looking for. Do a search as I'm certain there are threads on this
Keith we should meet up sometime, I am in Somerville. As for oil, I used Amsoil 5w-20 for the motor and BG Synchroshift II for the transmission. It's a solid combo...the amsoil is good for 10K+ miles...it also helps with the brutal winters we get up here.
I use all Amsoil in my RA and never had an engine failure and transmission failure. Everyone has their own preference. Im an Amsoil dealer and ive been using it for the past 15years. All 10 of my vehicles use it and never had issues. Castrol and mobil1 are good as well... RP and redline are good also. Both have high viscosity. All depends on how much you want to spend and what you want to do.
5 quarts of amsoil and a filter will run you about 50-60 bux. You can buy BG Synchro for about 35 bux shipped from Burschur racing. it's expensive oil, but your car will truly appreciate it.
Keith if you need any local help with your car feel free to PM me.
