Reflash and GT TB = Lean Code
#46
Read my post in the how-to section about how to effectively increase airflow to the engine with a big air pipe and avoid all the problems you mentioned. If you aren't going to use a mini-battery then a couple of extra bends in the piping will be required. Any SRI in any engine bay will suck in hot air unless you have the filter in an isolated box with foam sealing out air except for where you want it to come in from a cold source - which sounds a lot like the stock airbox, right?
#47
#48
Run an SRI, and still use the snorkel? Do you mean that the snorkel is just open on the back end, not connected to the SRI, but instead you have a cone filter hanging there with the snorkel facing it?
Makes sense.
Oh, I didn't move on to page 4 before I replied. I've seen the instructions and photos of the custom airbox that RalliartN built, but I forgot about it. I'll take another look. Thanks.
#49
03GS-T
Jun 11, 2016 07:26 AM
DynoFlash
10
Apr 21, 2008 11:06 AM
