4g69 swap
4g69 swap
So my 04 RA, has seized. i didn't take proper care of it as i had recently lost my job and it was low on my list priorities. I found 4g69 from an 09 eclipse at a very good price($750). so my thought is to just swap it in, and was wondering if you guys could point out some things to look for, whether it will be a doable thing or not. i have reasonable knowledge of cars and all the tools i would need to do it myslef but cant be buying a new tranny and dont really want to mess around with modifying the wire harness.
TLDR; will a 4g69 from an 09 eclipse fit nicely into my 04 ralliart?
How would i find out if i can bolt my original tranny to the eclipse motor? wont it have a different bolt pattern or something? i cant seem to find the specs on the transmissions of both cars.
i dont see why it shouldn't work. unless the crank is different and its like a 6bolt. im pretty sure ours is 7?
im fairly sure it should work since you're asking just about the block. only thing i'd wonder is if its the same oilpan. i know the one from the outlander has a different oilpan that didnt fit our car from another thread.
TrevRoar
Apr 13, 2015 10:59 PM
doncarbone
Feb 2, 2014 11:31 PM
