Problem: Crank w/ no start
Just a follow-up on this thread, car is in wonderful working conditions with no other problems. Mech said the first compression test he pulled was ~10 across the board but after retreating the cylinders with some heavy oil it slowly started to climb with last compression he pulled was ~125 across the board, he had no doudts it would return to normal.
He said there is a local guy that has the same problem with the last two nissan sentra's he has owned but not with any Mitsu besides mine, possible problem could be injectors leaked gas into the cylinders when it wasn't running causing the cylinders "dry up".
Zombie Killer
Feb 9, 2020 08:10 PM
OneEyedJack
47
Sep 9, 2010 07:30 AM
bboy_RES
10
Dec 16, 2008 07:39 PM
