tranny problems...still really
#31
If the brake master cylinder reservoir isn't full to the top it won't send fluid to the clutch master so when you go to bleed it air gets in the system from lack of fluid from the brake master reservoir so when you do bleed the system make sure it's full and fluid is leaving the reservoir when fluid comes out the bleeder. I thought I had a clog and the fluid was at the max line I took the tube off that goes to the CM and nothing came out til I filled the reservoir til it was almost over flowing than it came out to go the CM. Also I was able to stretch/ bend the first half of the metal clutch line from the CM to go to the slave cylinder eliminating the block thing ( can't remember the proper name)
I called a transmission place and he said that he doesn't think its a disengaging issue but more so to do with the new components and the fact that i cleaned up 1/2 gear probably just need a bit more time to run in say 2000 ish kms since ive only driven like 300. He also suggested i go back to an oem oil after this breaking in period, so im either goona go oem mitsu or the gm synchro mesh that everyone raves about.
#33
I replaced both my master and slave and cleaned out my reservoir.... you probably won't believe the crud i found... but I'll post it in the next few days.... but clutch feels way better now. used 1L doing the traditional bleed, and .5L doing a reverse bleed
#34
hey man let me know if u can only buy a large amount from mitsu like enough to do 2+cars ill split the cost with you( ithink when i asked them they could only order like 5l jugs lol so let me know
#35
on another note to anyone weighting in on this issue, zmax transmission fluid anyone know anything could it be benifital if so Canadian tire has it fro 25%off this week, what about the zmax engine oil stuff any good or just a waste of time?
#36
Never heard of zmax.. I wouldn't try it just because the fact if the gears do grind its a waste of money or on the other hand it can make it shift better.. I dont have money to burn like that but you do why not? Wait so when you bled it you mast was 3/4 below the fill line or above? I would try bleeding it again but make sure the brake master is to the top passed the fill line to the top of the reservoir..
#37
#38
I have used the zmax oil and fuel additive kit. I like their infomercial I guess it did it's thing but I didn't notice any change in acceleration, gas mileage, or anything for that matter . So they won't get me twice. Not to mention the 30 dollar price tag, on top of the oil and oil filter :
#39
Does anyone know about the tranny one tho and if it does anything to what they claim?
#40
I just bought redline MTL in mine and I ran this when I changed my clutch and it feels fine the fluid that was in it before sucked and on the redline website it says MTL is the equivalent of gm synchromesh But the mt 90 does say Mitsubishi and also works were synchromesh is recommended Ill try that next time I change my fluid..
#41
so i notice a difference from cold to warm weather in the shifting of my car, im also concerned that the dremel grinding i did to the surfaces of the dog teeth on 1/2 gear is why those gears are so bad and rough when the selector is engaging them do you guys think this will eventually wear in and become a little smoother with the amsoil i have in?
or should i just drain it right away and put something better like the redline mt90 or just go back to the oem before i wear it anymore or should i go through the full breakin 2000kms and then do? (which is going to happen either way)
#42
As we have said before Amsoil sucks in the transmission and killed my synchros in 20000 km. it's too slippery for the synchros to have enough friction to speed up or slow down the gear sufficiently to have a smooth shift.
I would take the amsoil out and put in OEM or 'GM Synchromesh Friction Modified' if I were in your shoes (I would personally use GMSMFM)
#43
As long as the wear faces of the synchro are okay I don't see how sharpening the teeth would negatively affect to a great extent the shift feel... the teeth just allow the collar to slide on to it and act as a ramp to prevent the collar from prematurely slide on to the gear teeth if it isn't synchronized. Friction between the synchro and the gear is what allows them to slow down or speed up to synchronize the speed, so the wear faces have to have enough material to do that.
#44
I think you need to be very carefull with the claims you are making you seem 100% sure about them.
And you havent talked about how well was your tranny before the AMSOIL fluid, you haven't stated how bad was your clutch or your clutch adjustment, fluids won't stop a system from breaking they may surely help,,, at the end of the day an Evo is a performance car so we all know they are driven as such so when the drivetrain is not top notch and taken care of properly they will fail quick,,, why do you think shephard builds thousands of them a year.
It has been proven over and over that 90% of the time tranny failures is due to operator error not knowing how to maintain them or shift them,,, and given the fact that over 500 quarts of MTG were sold last year only for evo's, so in this case of having you and maybe a few others having issues leads me to believe there is a possible mechanical issues before hand
#45
I am an amsoil member. I use amsoil in all my engines. It's a great product in the engines. NOT in our transmissions. Seeing how many Subarus also have problems with using any other fluid than OEM in the transmissions, Amsoil is not the best way to go in all transmissions.
Last edited by Canada_Comp; May 9, 2012 at 10:05 PM. Reason: added references to post 10 and 13
