04-06 Ralliart Engine/Drivetrain (no forced induction)
RPM shift point, when do you shift? 06
Old May 11, 2012, 09:30 AM
soulesswarrior's Avatar
Originally Posted by 2006_RA
I still find the throttle difficult to control from idle to about 1200 rpm, and that's after 4.5 years and well over 100 000 km. Only car I've had this issue with. You barely look at it and the engine goes racing away, probably have to sneak up on it with a light flywheel, but I still want one.
Light flywheels rule.
Old May 11, 2012, 10:18 AM
$MIVEC$'s Avatar
~2.5k rpms to save gas
Any other reving just to feel the car....redlining is fun
Old May 11, 2012, 11:24 AM
CrAnSwIcK's Avatar
7200 with boost
Old May 11, 2012, 11:35 AM
Talon's Avatar
Originally Posted by johnnycage
I know I'm not over working it, just sounds like it in 1st going to 2nd around 3500rpm. It's also jerky in 1st if I give too much gas.
That's on you, dude, not the car. Different people drive different ways in different environments, that's the beauity of a manual. Shifting between 3-4k is perfectly normal.
Old May 11, 2012, 12:57 PM
RacerX-Ralliart's Avatar
I have te evo 8 dash and redline Gets to 6800rpm before it falls on it face..but shifting at 6k I think would be bet since it does fall right in torque band I'll have to hit the strip and compare to my previous times.. If you bring rpms up slowly the car sounds like its being overworked cause it's like shift or slam on the gas! You have to feel the car my first stick didn't have a rpm gauge so I had to "feel" it my dad said I used to shift at 10mph to second and 20mph to third thinking the only gear that could go to high speeds was 5th boy was I wrong.. 7200 full boost would be REALLY FUN
Old May 11, 2012, 01:20 PM
johnnycage's Avatar
Thanks a ton guys, this has helped. I had a feeling there was nothing wrong with shifting around 2-2.5k rpm. Just feels like thats the smoothest for me. I'll work on driving nice n smooth in 1st.
FX11
31
Feb 12, 2019 08:54 PM
eddy5201314
Jan 25, 2017 08:06 PM
DAN123AC
Mitsubishi TC-SST Discussion
Aug 1, 2013 06:26 AM
detroit pistins
Nov 24, 2008 10:40 AM
evo_skillz
Dec 30, 2006 06:09 AM
Quick Reply: RPM shift point, when do you shift? 06
