evo crank pulley on a 4g69?
so i saw on ebay that a lightweight crank pulley for an evo fits a ralliart im wondering if this is correct? If so anyone know a good light weight crank pulley that isnt an underdrive?
Also does having an underdrive effect the voltage coming from the alternator? i know the smaller crank pulley would turn the aternator less but how much does it effect the car?
It all depends on the ratio of the crank pulley to the other pulleys. The kit you seen was it the one that came with the alt. power steering and water pump pulley? Most people are worried about their light dimming from a underdrive pulley but what the should be worried about is the water pump turning slower.. Lightweight would be the way to go anyways from the pictures it looks like itll bolt it But I'm not 100% sure As I never bolted one on
anyone else??
