motor wont crank timing belt doesnt move???
wow, really? all that speculation?
your timing belt is stripped, you won't hear the valves colliding with the pistons...if it failed at low RPM the valves might still be ok...replace the belt, and check compression, if outside specification, you'll have to pull the head...if the head needs to come off the repair cost would be several hundred even doing the work yourself, the head would have to go to a machinist...just get a new timing belt to check compression and report back.
there may be no valve damage...
broken cam maybe? sounds like something def broken, doesnt seem like it could even be a sensor yet something could be so worn that certain sensors arent getting the info they need
the timing belt is stripped, there's no way the cam is broken, and the cam is mechanically coupled to the crank via the timing belt, so if the crank turns and the cam doesn't, the timing belt has failed, no sensor or any other factors will cause the two of them to move independantly...i don't even understand why this is up for debate...
This actually happened to me with 148k miles on my 04 RA. The timing belt got stripped away and the valves hit the piston and crack the heads.
I'm currently fixing the car i'm so far in like 3k in parts and labor and thats with a couple of aftermarket items. I bought an engine and i'm just waiting to get my engine and parts in to fix it all and i don't know what to do with my old engine.
my first guess is u may have jumped a tooth if the timing belt hasn't been done in which case u would could a bad reading between the crank and cam sensor and it wont start the car,
if the rest is turning but the timing belt isnt check for tension in the hydraulic tensioner and check for missing teeth around the crank pulley and the cam pulley.
edit 1 i should have checked the dates i didnt realize how old this was lol
hey guys found out what the problem was my timing belt didnt break but the teeth came off the belt which i guess through it off time. about to order a new timing belt but should i get the kid for it? what would be best? should i replace all the tensioners? i found a kit online only for 86 bucks but does anyone know the process of taking off the bottom cover? do i have to remove the water pump too bc some kits come with a new water pump? any help would be great hope i didnt bend any valves...
edit1 mitsubishi parts.net has a 10% off store wide disscoutnnright now go look under the specials arear to get this code it will tell u what is excluded
Coupon Code: bWAXNpw7
Coupon Desc: 10% OFF SITE WIDE
does anyone know where i can get a timing belt cover (bottom) or would it be called the camshaft cover? can't find it anywhere it cracked when i took it off...and thank you everyone for all the help
sorry ya crankshaft* and it was so brittle when i slid went to pull it off it just cracked through and the crankshaft plug was kinda stuck on the sensor. but i cant even find it new but i haven't checked the dealer.
