Help! Flywheel bolts are too short?? 06 ralliart
#46
Today I went to the garage and had my mechanic unbolt the flywheel so we could do a side-by-side, flat surface comparison. You can see clearly from the pictures that the ride height of the flywheel is way higher on the Clutchmasters one.
I've also attached a picture of where in the bellhousing the clutch cover is rubbing. The crank is pushed all the way in, we are doing nothing wrong it's just terrible R&D and QA on Clutchmaster's part.
I am dealing now with Road Race Motorsports and Clutchmasters and I'll update with what happens next.
EDIT: If you look at the last pic, you can even see the yellow paint chips in the bottom right where the paint was scratched off from the clutch cover
#47
lol, what do ya know? it's like a ¼" thicker...lol, and it looks like it's rubbing the inboard output shaft bearing "housing". you don't want to remove material from there, lol
i wonder if it would work only with a clutchmasters clutch...i also wish i could measure my ACT stage 1 for you...at least get an idea of WTF is going on...
#48
i am just hoping that the rep from clutchmasters sees this thread, sees the pictures and does something about this because it's a lot of money to blow and even more time to waste.
EDIT: btw I see you've reported the hp/torque for your car - how much wheel spin do you experience? is it starting to border on becoming a little too much power for the two front wheels?
#49
but seriously with street tires, it's not that bad, hackish programs a 2-step launch controller into the ECU program, for the clutch dumps, and when you get used to it, it's very manageable...i also have an LSD, so that helps too...with a good sticky set of street tires, it's just like stock, but faster...
#50
not with slicks
how long have you been driving with ur turbo - is it still reliable, have you faced any problems?
#51
not really no...it's been a lot of fun...reliable so far...i did a 6,000km+ road trip with the family, and the car fully loaded with food, and luggage...that was worse on the suspesnion than the motor, and i drive her hard at the track all the time, and it's been solid...
#52
#56
EDIT: The motor and the ECU are both 2006 - so I guess I can do that UVtune/tactrix cable thing...really no idea how to do any of that though haha
#57
by the way i also found out that my motor/ecu has on it 95,470km - do you think this is a bit high to be considering turbo?
tranny I believe is 65,000km.
the following are brand new:
- headers/downpipe
- exhaust
- motor mounts
- air intake
- radiator / fans / silicon hoses
- flywheel (if ever this issue gets resolved, that is -__-)
- clutch
- throw out bearing
- all belts and bearings (complete kit) including water-pump
- oil filter
- alternator
- clutch slave cylinder
- exhaust manifold gasket
- brakes / brake lines (wilwood big brake kit)
- suspension (tein basic coilovers)
- control arms, misc bushings
- anti-sway, strut bars, lower tie bar
Any recommendations for what I should add/replace if I am going to consider a turbo kit in the future or is it an unwise choice to begin with? How much an impact did the LSD make?
- headers/downpipe
- exhaust
- motor mounts
- air intake
- clutch
- throw out bearing
- oil filter
- alternator
#59
