SAFC on Lancer Ralliart
Originally Posted by reTro
Super Air Fuel Controller
Basically it allows you to modify the air/fuel ratio.
Super Air Flow Converter - changes the air flow the ecu sees which then adjusts fuel trim which changes the air/fuel ratio
It takes a lot of effort and neglect to blow up a NA car since the margin for error is much larger than FI.
RRM PB = already done all the leg work
AFC = you do all the tuning, and it's flexible to a certain degree to your needs. If you do sell it, almost any make or model can use it.
El Boricua
10
Apr 22, 2009 06:27 AM
shadow1
Jun 2, 2008 05:37 AM
MattGold
Jul 29, 2004 09:46 AM
