So, what's the deal about MIVEC...?
#31
^^^ inside the car, so I can see if it switches @ 3500rpms, but now that you mention... ill pop the hood and try the throttle cable instead.
#34
Here is a quick vid (mostly just for sound purpose). I put the silencer on my exhaust and it's kinda windy, but it's there so listen carfully, ull here a lil switch and the engine pitch get higher. I don't stay in MIVEC long, just so you can hear the cam profile. On the 8th revv, i stay in MIVEC for alil and you can hear the engine pitch scream a bit.
Here is the times for the MIVEC cam profile ( I used WMP):
12sec
19sec
24sec
31sec
36sec
40sec
47sec
56sec
1.12sec
http://s4.yousendit.com/d.aspx?id=0N...71BRZAXMW3B4S9
12sec
19sec
24sec
31sec
36sec
40sec
47sec
56sec
1.12sec
#36
http://s47.yousendit.com/d.aspx?id=0...Q3R5NG91ZVLQOF
Can you hear my cam changeover? (not the Ralliart)
#38
I read in several articles that Mitsu designed MIVEC with three different cam profiles(low, med, and high) as opposed to just two, like VTEC and VVTL. I think this is a major cause of the "less kick" that has been described in this thread because the increase is spread over two profile transitions. The only thing is I can only find mention of a 3500rpm switchover, but nobody mentions when the other takes place. Is 3500 the low-mid switch or the mid-high? When is the other one?
#39
Yeah explain what mods you have, I'm running all the bolt ons, (headers/dp, udp, aem cai, timing box, pnp mani, and the piggyback), now I had lost some bottom end untill I threw on my piggy, and rrm tinkered the map a little bit and there is a huge change. Launches gres and you can deffinatly feel that kick on mivec and I have felt nothing but gains all around the power band. Actually just did a run with a s2000 and a celica gts. Took em both.
#40
#41
people dont understand this at all...theres no kick-in...you dont want a kick-in mivec is always working it doesnt just engage, if you tune your own car you will find out that theres a MAP for it, also it only changes cam duration (timing) not lift thats why its variable valve timing not a variable valve event, think of MIVEC like a computer controlled adjustable cam gear, it optimizes where peak lift will occur during the combustion cycle (how many degrees before top dead center) to control where the cars powerband is and give the car that ability to feel like "it just keeps pulling", more information is pointless unless you grasp that
#42
#43
