Shaking Steering Wheel
Hey I've noticed that my steering wheel vibrates a little @ high speeds like around 80mhp I was just wondering if you guys have also experienced it. I tought maybe it was a rocking pinion but this car is so new I don't so a lil' help thanks
you may have a wheel out of balance. My 18"wheels get out of balance every now and again, but the only time I can tell is at high speeds on the highway. When this happens, the steering wheel vibrates like you are talking about. Hope this helps
Check your lugs to see if they came loose. When i just installed my CAI when we went to put the wheel back on 2 of the lugs would just spin and not go on all the way. We had to take 2 off the back and put them on the front and it worked, and the 2 from the front worked on the back LOL. Im going to bring mine in to get looked at and if they wont fix it im going to have to do it myself cause at least 2 are a bit striped. so i would check that as well since i had this problem @65mph. GL also man.
Location: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
allignment would be sumwhat an issue if it pulls either to the left or right whle driving straight.. while ur brakng does it vibrate.. if it does then its brake issue... meaning ur rotors are uneven n needs to be turned, i.e. resurfaced.. but if it vibrates at excessive speed then its wheel balancing...
Seems like everyone has covered all the bases pretty much, only thing i can think to add is, how long has it been going on? is it a road you travel a lot... even so I know the freeways over here in phx are getting redone right now, but the parts that haven't been are horrible and have little dips in them that i can feel through my steering wheel.... maybe its the road... cause i know through a section that i travel it's pretty bad not where the steering wheel shakes horribly but enough so i can definately feel it in my hand
laxplayer14
Oct 20, 2014 06:06 AM
bakerunc22
14
Dec 27, 2010 01:52 PM
Kracka
Jun 8, 2010 07:50 AM
