Installed AEM CAI today
Well I finally got my CAI from AEM the other day. And today I installed it. Check out the pics. So far from my little test drive....I am loving it. It looks a bit different than the Injen, and install was cake.
I absolutely love how mean it sounds once MIVEC kicks!
Installed the Speed Source brass shifter bushings while I was under the hood too....crisp shifting .
Originally Posted by rocketman
Can it be converted into a SRI and can you use a bypass valve on it?
I'm not sure about converting to SRI....seems like if you took the down-tube off and put the filter on the shorter tube that the filter would be real close to the valve cover. For the SRI's I have seen, the filter is positioned more behind the battery.
