pinging engine noise due to aftermarket.....
Old Oct 20, 2005, 10:42 PM
Myszkewicz's Avatar
Originally Posted by otter
Be prepared to burn your hands. I wish Mitsu would publish the cold specs, would be easier to check and set the lash.
So... set the clearance while it's hot, then check it when it's cold, and get back to us.
Old Oct 21, 2005, 08:51 AM
EvoM Administrator
otter's Avatar
I did some more reading and found that when the valve lash is as tight as ours, you MUST set it when hot It seems that when the engine is cool, the rocker can actually touch the valve, which means you can't effectively set it.
Old Oct 21, 2005, 09:55 AM
Myszkewicz's Avatar
Yeah, I figured it was something like that. Especially when I was looking for a suitable feeler gauge set last night. The "tappet feeler gauge" set started at .3mm, which is WAY too big for setting the intake clearance. I had to get the "master feeler gauge" set to get smaller than that. It goes all the way down to 0.038mm.
Maybe I'll do mine this weekend. I was going to do the solid motor mounts, but they haven't arrived yet. I ordered them last Sunday. The urethane and primer are ready to go, though.
Old Oct 21, 2005, 10:30 AM
EvoM Administrator
otter's Avatar
One of these should make the job a lot easier, especially if you have to make adjustments.
http://www.amazon.com/exec/obidos/tg...21404?v=glance
Old Oct 21, 2005, 03:24 PM
Starlite Demon's Avatar
i just read on the US lancer forums concerning about an engine noise... i do notice the noise does not happen when the clutch is in but when i released it it does... they say its the TOB (throw out berring) so i guess you can check your whole clutch thing.... and i also heard that its quite common with manual mitsubishi's? oh well just some info....
Old Oct 22, 2005, 12:49 AM
jwhitey's Avatar
Is this a pinging when it's off and cooling down or while running?
Corbin09
17
Oct 24, 2014 09:12 AM
Nickzorz91
Sep 26, 2012 06:34 AM
k270kmh
23
May 14, 2007 01:00 PM
Mercenary3
Mar 19, 2007 06:05 PM
sushiman
Nov 29, 2006 10:49 PM
Quick Reply: pinging engine noise due to aftermarket.....
