Does IX front brembo fit Ralliart?
I wish they make Brembo's for the lancer. If the bolt pattern is the same then the rotor would fit, all youd need would be the caliper mount. how hard can it be to make some for the lancer?
Originally Posted by S1monLM
Do they fit or modification required?
Next would be the caliper itself. The rotors will fit but you need to make brackets for the calipers so that it can accomodate the 330mm rotors. However the caliper is going to rub onto one of the original mount points of the old caliper which means that the caliper needs to be shaved down.
I think you may be better off with a two pot caliper with larger rotors from RRM....
