How to convert from 9007 to H4?????
i wanna buy a pair of projector head lights that comes from ASIA and the plug that they uses is H4
can i convert from 9007 to H4?????????????
Originally Posted by Ralli04Art
it comes witht he conversion kit
they send me the H4 plug and the wires with the projectors, right???
i just need to buy a 9007 male plug and connect the wires on the plug, and conecte it to the original cars plug??????????????
Dont even need a conversion kit. H4 has three prongs refer to the attatched pic. 9007 socket has three wires. Middle is ground. One is high beam and the other is low beam. Use a multimeter set at 20V to test. Connect negative from multimeter to gground and then connect positive from multimeter to one of the wires, if no voltage is seen then the other is the wire getting the power. After determining which is the low and high beam just wire it up to a 9006 harness and your done. PM me if you need help. Im doing a similar thing in my oz.
Speed Element
16
Apr 7, 2006 11:31 PM
ARVSHOP
Evo 'For Sale' Exterior Styling
17
Mar 7, 2005 08:49 AM
9006, 9007, buy, change, conversion, convert, converting, covert, electronic, frys, h4, lights, male, plug, socket
