Speed source brass bushings
I just purchased the speed source brass bushings for both the shifter base and under the hood. I will review once I receive them and maybe do a quick write up on the installation if there isn't one already.
Grease the hell out of them, particularly the ones that go under your hood. Grease the pins they go on and the cable ends they go into, too. Otherwise, in a couple years, you'll be pressing your speed source bushings off the pins and out of the cable ends, because they will bind up and make your car almost impossible to shift.
The only other installation tip I can remember, I pulled the little clip out that holds the shift cables into the bracket on the transmission. That made it MUCH easier to get the bushings to line up with the pins once they were installed in the cable ends. Then the cables just pop back into the bracket, and push the clip back in.
Thanks for the info and the tip. I remembered reading the threads explaining the problems with the brass bushings so I searched the evo threads earlier for more information. It seems most have not had trouble, and the biggest issues arose from the initial fitment, whether they were super tight to begin with and possibly if the installer had cleaned the bushing seats before installation. Also, the posters were recommending anti seize instead of grease. Does this stuff take longer to break down than grease??
Grease or oil will break down with heat, dust and dirt will stick to it...... Anti sieze all the way... I have used anti-sieze on my U-bolts that hold my axles to the leaf springs on my rockcrawler and dragged it through the nastiest of rocks, muds and dust and everything comes apart like butter even after 2-3 years of pure abuse... Don't get it on any clothes you like, it will not come out...
Yeah, some guy had to get a gear puller, another used a dremel tool and cut one out. I guess it will have to be a regular checkup thing like spark plugs and air filter. I try and check on both of those things every few oil changes to make sure they are doing ok. Anti seize it is then, since it seems to be the better option.
eclipse2lancer, how much of a difference, as good as the clutch slave delete was? I am looking forward to getting these, how excited should I be? Like this ---->
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
I'm using them and I really like the difference. It's pretty noticeable and its much more mechanical feeling for lack of a better way to describe it. It feels much more precise. Again, use that sandpaper! Get the bushing sanded down to where they fit easily in the linkage cable ends, this is probably the number one thing to do in order to avoid them seizing up.
But I like the brass bushings....I would say your excitement should be somewhere between this:
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
and this:
![](http://i81.photobucket.com/albums/j239/eclipse2lancer/spinnas.gif)
