gauge install
gauge install
Can someone help me out, i have searched but can't find the info i'm looking for, i bought a Oil pressure and Oil temp gauge, which come with 1/8 npt electrical sender units, i'm looking for a oil block adapter, found one from Greddy, which is M20 x P1.5 & 3/4" x 16 unf fittings 66 & 70mm o-rings, is this the right one for our car, also does this adapter accomadate the 1/8 npt sender units or will i have to retap, or will i have to go with another oil filter adapter, anyone one know if it will work or know of another adapter that will accomadate my 1/8 npt sender units Thanks
take a look at 42draftdesigns.com. they should have something that will work for you. not sure about the greddy, i have seen it around, but no first hand experiance. A friend of mine has one on his gsx, ill check on the model numbers and stuff, i would assume its the same
![Dunno](https://www.evolutionm.net/forums/images/smilies/dunno.gif)
Jp7
Jul 30, 2017 05:29 PM
dtfrost5
May 13, 2016 06:33 PM
