Tire PSI
1 Post
i usually go 2-3 psi above the stated pressure, and check it with my own gauge as the ones at service stations often lie, different readings place to place etc. I found when I put a bit too much in the fronts and they got hot that they rubbed a bit when turning on a bumpy surface so usually around 37-38 on the front (35 stated)
I have been wondering about this too but I have been running 38 all around on my 205/40R17s because thats what I was told. But the stock tire pressure recommends more in the front than the back. Would that still apply on aftermarket rims or not?
tire pressure is subjective, but generally speaking you need to run between 30 and 38 psi on the street. it depends more on your driving style than your rim size. more in the front is to force understeer instead of oversteer, or at least that's what I can figure. (not that understeer is a problem for the stock suspension )
Lol, I was about to when my search didnt work out but then I decided to read through the Wheels/tires/brakes/suspension/whatever else(lol) first and I found it. I like doing that because that way I go into a bunch of other threads that look interesting and learn new stuff.
along your line of thinking I would hypothesize that the front tires are overinflated (compared to the rear) because of the huge understeer already present in the RA. actually, now that I am going over it in my head it makes more sense that way anyway, as (and again I may be talking out my *** again) I believe the uneven tire pressure(at least front bias) is predominantly in FWD vehicles. I haven't had to inflate too many RWD car tires, and no AWD, but it makes sense.
btw, my original line of thinking was safety. understeer is much easier to control for an average driver than oversteer, so from a safety standpoint you want understeer all day.
I'm running 30 30 30 30. the tires recommend between 30 and 45. The car doesn't seem to understeer to me unless try to accelerate within in a corner. This makes total sense considering it is front wheel drive and a rear wheel drive would probably oversteer with the same inputs.
Consider that where the front wheels would travel straight in a FWD while the rear wheels grip that the rear wheels would travel straight in a RWD while the front wheels would grip.
Actually, the balance of the ralliart is pretty good, the lack of a LSD up from probably provokes more oversteer under acceleration, which is to be expected.
You can get around pretty fast without squealing your tires. at 30 30 30 30 the tire wear is very even and the tires are still good after a year which is a miracle for me, although I'm sure it definitely depends upon the tires that you use.
