removing door panels...?
anyone have a diagram or "how-to" for removing the door panels to get to the speakers? i did a few searches and couldnt get anything
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
![](http://i81.photobucket.com/albums/j239/eclipse2lancer/Frontdoortrim.png)
1.CAP
2.PULL HANDLE BOX
3.POWER WINDOW SWITCH PANEL ASSEMBLY
4.DOOR INSIDE HANDLE COVER
5.FRONT DOOR TRIM
6.FRONT DOOR PULL HANDLE BRACKET
I believe you can just undo the outer screws and the handle cover, then you can pop the panel off. Pretty sure it has plastic tabs as well. Careful of the wiring harness to the window and lock switches when removing.
![EvoM Administrator](http://forums.evolutionm.net/images/titles/admin.gif)
I don't have it, but our doors are really, really easy to get off. There's a screw in the pull handle, behind the latch, and at the front and rear edges of the panel. All the screws are covered in some way. Get all those off, remove the inside cover for the rear view mirror, then work the snaps out around the bottom of the door. Helps if you have a trim tool, but it's not a must.
bigd31388
33
Aug 20, 2012 07:59 AM
Noob4life
Aug 20, 2006 10:11 AM
