Fog Light ?
Fog Light ?
so i was looking at both of my fog lights and the right fog light seems to look like it has an inner crack in the plastic cover. like a straight like deep in the plastic but no cracks wat so ever on the outside. im thinking this is the way they are made. if possible can anyone give any advice, maybe take some pix of both fogs so i can see if its just me. thx
Yup... if you dont replace it you will eventually have a fog light half filled with water. Just like my buddy in his Rx-8, during rainy seasons in fills half way up with water. He called it the aqua-look
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
Yeah I have the same thing in both of mine, I accidently dropped mine on the ground from like 2 inches and it cracked one. And I dont know how the other one got cracked, happened after I re-installed it after painting them.
idk someone looked at it and said since i have the ralli edition maybe they made it like that, or wat im thinking is that there so fragile thats y it could b occuring 4 alot of us. or do u think its just the drain pipe that we see?
yes is has or had a ralliart....
But as far as the drain pipe, definitely not what you're seeing. That "pipe" that i'm talking about is the little rubber hose that comes off it and surrounds the wire coming out of the ballast. It prevents water from getting in and most likely allows water to get out since its located below the ballast. As for the crack, its definitely not right and its definitely unfixable. Its not external, and unless you want to rip apart your lense and put some ghetto "glass repair" glue in it you're sh*t out of luck. It doesn't affect my light beam at all so I just leave it. Soon enough I'll just buy some cheapo "Yellow stained" ones from ebay for about 75$.
