Problem after 10 min
Old Aug 30, 2007, 06:59 PM
ali911's Avatar
the car is shutting off after about 5min-10min of driveing or idling
my rad fan is working fine and rad temp is fine.
what could be the problem guys??????
Old Aug 30, 2007, 07:04 PM
ali911's Avatar
forget to mention after the car turns off i wont be able to start-up.i have to wait a while til start-up
Old Aug 30, 2007, 07:38 PM
ixhavexfaithx's Avatar
use the clutch?
jk
Old Aug 30, 2007, 07:40 PM
bruce988jl's Avatar
time to go to the dealer.. is the Service Engine Soon light on? Might want to get the codes pulled or something...
Old Aug 30, 2007, 07:44 PM
ali911's Avatar
the service engine lights came on for a bit, not any more
Old Aug 30, 2007, 07:45 PM
ali911's Avatar
Originally Posted by ixhavexfaithx
use the clutch?
jk
u think
Old Aug 30, 2007, 07:57 PM
bruce988jl's Avatar
now.. does it bog down? and like completely jolt to a stop, or does it just like slowly die..
describe to us your problems Ali... we're here to help, tell us don't be shy.. haha
btw you have 30 more minutes left to your therapy session... anymore and it'll cost.
Old Aug 31, 2007, 03:47 AM
DangerousDan's Avatar
what code is stored in the ECU? are there any issues with driving the car, or will it not function normally at all? Meaning can you drive down the street even though you know it will cut off, or will the car not move without an issue? Have you actually timed it out to 5-10 minutes or are you guessing? The time line could be important in diagnosis, so be accurate. have you changed anything recently? does it make any noise?
it sounds to me like your car is fine on a cold start, but after warming up it doesn't like something it's getting from one of your sensors. if you have the code pulled it should point you to the offender, or at least the system that is causing the problem.
Old Aug 31, 2007, 05:03 AM
bruce988jl's Avatar
Is your car under warranty? If so it might be easier just to take it to the dealer and have them diagnose it. Sometimes... rarely.. its easier..? But yea I took full advantage of my warranty.
Old Aug 31, 2007, 07:59 AM
EvoM Administrator
otter's Avatar
This problem is impossible to figure out with the limited information you've provided.
Old Aug 31, 2007, 09:04 AM
EvoM Community Team
migs647's Avatar
You said the CEL light came on then went off. Make sure the light isn't blinking or any kind of flashing which could mean SERIOUS problems. If it is stop what you are doing and TOW it to the dealer. Please give more info.
Old Aug 31, 2007, 09:15 AM
CDO
CDO's Avatar
Probably won't help you much, but I had a minivan do the same thing. It would just die at times and then anywhere from a minute to a half hour later it would start up again. Some electronic part in the distributor would overheat and cause the engine to shut down.
Took it to a few places and none of them could figure out what was wrong because the code would erase when it started back up so diagnostics showed nothing wrong. The last place I took it to just left it running till it died and then figured it out.
Old Aug 31, 2007, 09:27 AM
bruce988jl's Avatar
check for a loose battery terminal.
Old Aug 31, 2007, 10:23 AM
ali911's Avatar
the car is still under warrany but the problem is the car was imported from the us.dealer service manager is off for couple days
Old Aug 31, 2007, 10:27 AM
ali911's Avatar
the car was running fine until i changed the accelerate cable"700-600 idleing".after aprx 10 minu of driving the car will shutt off on a trafic or stop sign. it is like fuel is cutting off but it is working fine unless it is the fuel filter
