Guide.. How To Make Foglights Turn On Ralliart 2006
Here's a short video of my high beams (Silverstar Ultras) with the stock foglights on.
sexy, no?
http://www.youtube.com/watch?v=b1467k0dbtI
sexy, no?
Deciding to bump this thread. I had a random idea when regoing through this and just wondered if the ground power is what is cut... would there be a problem of just splicing a wire from the ground wire to the negative terminal into the battery? just a wild idea. any thoughts?
Try it, post results for all to see
: mitsu::m itsu::mi tsu::mit su::mits u:
I don't think it's that simple. I Belize the computer has to see a ground from your headlight swith, then it will allow the fog switch to function. I could be wrog but I do recall reading something about this a while back, because I had the same thought if grounding the switch but was told it wouldn't work....
E46byeRAhi
17
May 19, 2017 04:26 PM
