Starting problem
Old Dec 25, 2010, 05:05 PM
kemikal4402's Avatar
Starting problem
I have a 2004 Ralliart and it doesnt seem to want to start (or do anything for that matter) I replaced the battery and altenator. It will turn over if I jumpstart it, but wont hold a charge and once I turn it off after that, good luck getting it to start again. The battery light is on and I had the voltage checked and was told that the altenator is good and is generating voltage, the battery itself is good (pulled it out of the car to have it tested separately) I heard a clicking sound months ago coming from the car and was told its a sign the starter relay is going bad. When it used to start, sometimes I would get a small amount of smoke coming out of the steering column, it would stop coming out but will still start normally. Anybody out there see this problem before?
Any help would be appreciated,
Thanks...
Old Dec 25, 2010, 05:08 PM
Flip's Avatar
Thanks...
so the batt and alternator are good?....did you try taping the stater to see if its just a bad contact on the inside? or maybe the starter relay you mentioned? check to make sure the plugs arnt fouled? did you check anything else?
-Flip
Old Dec 25, 2010, 05:25 PM
GearDownSon's Avatar
See if you have a short in the system. Replace your battery connectors as well.
bboyirra
Sep 17, 2013 11:55 AM
CamShaft
Lancer Troubleshooting
17
Mar 19, 2013 08:05 AM
iitzbebo
May 30, 2012 12:11 PM
9evolution
Nov 2, 2008 08:44 PM
aspensvt16
Feb 25, 2008 02:50 AM
Quick Reply: Starting problem
