Full Tune Up
Full Tune Up
So I'm at around 100k miles and i think it's time to do a full tune up. By full tune up, I mean, transmission oil flush, oil change, brake fluid, windshield fluid, radiator fluid, and spark plugs. What else should I do? Is there anything else I should flush? And does anyone have any how to's on any of these things? Suggested parts, fluids, and all that. I haven't seen anyone post this up so might as well do it. I wont have to do a timing belt/water pump change for another 20k miles so I'm trying to save up until that happens, but for now it's just the things I listed earlier.
Have you ever replaced the O2 sensors? If not it would be a good idea but not required. Also you could change the serpentine belt, air filter( if you don't have CAI or SRI) and the cabin filter. You pretty much got covered all the main things.
As for the how to's everything is pretty straight forward.
Good luck and Happy New Year!
Oil pump should be changed or inspected when doing the timing side of the motor. I myself would spend the extra couple dollars and get it done when your in there doing the timing belt saves yourself alot of headaches down the road.
The dealer quoted me $750 plus 13% tax. I would say if $600 includes parts then it's decent.
Unless you have recorded low oil pressure or found some other issue with the oil pump, I would say forget it. That is not something that usually needs replacement on a street car.
Freebs
Mitsubishi TC-SST Discussion
Sep 4, 2015 10:08 AM
