Glowshift oil pressure and A/F ratio sensor
Guys,
I've got three Glow**** gauge with the car when I bought it. Right now, I think the oil pressure and A/F ratios don't work properly.
For the oil pressure, the needle doesn't rotate at all. I test the voltage between the signal and ground which is about 9V. Does this indicate the oil pressure sensor is fine, but the gauge is down?
For the A/F ratio, the needle always spins from lean to rich very fast and fairly random. It seems have nothing to do with the acceleration pedal position. The voltage between signal and ground is always fluctuating from 50~760 mV, which is within the nominal threshold. And this signal voltage seems have nothing to do with acceleration pedal position as well. What's the problem of this one? The gauge or the sensor? This gauge connect to the narrow band oxygen sensor. Where is it?
Thank you very much!
the a/f right now looks like: http://www.youtube.com/watch?v=R2FxKSygGSA
I think it should be looks like: http://youtu.be/rw5TIty2TK4
I bought mine w a triple guage pod... Thry did a horrible job on install...but my A/F guage does the same thing. But my oil pressure is spot on along w volt. I always wondered if th af was hooked uo wrong...i just tell people it tells me my car is running. LOL
I get some other instruction about the a/f. Since this gauge is connected to the narrow band oxygen sensor, there could be only two outputs of +1 and -1. If we want to get the read shown in the 2nd video, we have go to a wide band one. That would be more complex. I think this make sense, but just not quite clear, if so, why they design this stupid gauge? And actually, the read I got from my digital multimeter is not simple +1 or -1!!!
narrow band is stupid and pointless, not simply -1 to +1, but it is not accurate at all...get a wideband...with a turbocharged engine you should already have a wideband...
does your oil pressure gauge sit at maximum, or zero? short the signal wire to ground and see if the needle moves, if not the gauge is ****ed, if it does move, the sending unit is ****ed...where is the sending unit connected?
I've no idea about where is the sensor so far. I don't have a stand. I'll check it later.
Another wired thing, there is one cord comes from the bottom of the engine, but it's a kind of Y shape. One end goes into the car, and the other end goes to the throttle position sensor. The cord was stripped at the neck of the Y. I believe this cord is an additional one, but I don't think all the three gauges have anything to do with the TPS.
BTW, I don't get the "short the signal wire to ground". Connect the signal wire to ground port? If so, with the ground wire on or off the port?
a short is a closed circuit, so yes, connect the signal wire to ground...that would be zero volts...having the signal wire connected to nothing, or open circuit, voltage is infinate and you should see maximum on the gauge...if you have a valid signal from the sending unit, and the gauge reads zero, it's likely that the gauge is not working.
for the narrow band AFR gauge, i can't say for sure, but i do know narrow band is not accurate and pointless to display...
xtnct
Jan 11, 2004 09:29 PM
