Blown fuse or blown window motor?
So I have had my window rolled up for the past 4 months.
Not too bad when its winter but now its starting to get a little toasty out so Im done being lazy about it.
Not sure if its a blown motor in the door or a blown fuse yet.
I went through the forums and searched but found a ton of similar issues that were resolved by turning off the windows lock button.
I assure you this isnt the issue.
I looked at the owners manual and they dont really show you what fuses are for the power windows.
Is anyone familiar what fuse I need to check for the driver side front power window?
Google even let me down.
With my luck the motor is blown but its worth a shot.
Yeah its just the one window.
I was fairly confident that it was just the motor.
Boo.
Well Im currently looking at replacements on rockauto.com (cause not one of the junk yards in my area have a single lancer in them) and now just want to make sure I am ordering the right thing.
Do I just need the motor or do I need a regulator too? First time changing one of these suckers out.
Attached 2 shots of what I have available for purchase...
Boo.
Boo.
Boo.
Easy to see once the door panel is removed good luck
I would personally remove the door panel and listen for activation of the motor.. Even remove motor and activate it to see if its ok. Could also be a window regulator.. Which is more common on the cars i work on daily
So my plan is to order what I need and then jet back to my parents where I have a garage to use. And just install.
But you think it might be the regulator?
Hmmm, well thats not good to hear... I would hate to see you order parts that may or may not be needed not alone not order the parts need to fix the vehicle. I would not rule out the regulator.. If the regulator is jammed then the motor will not move. The only advise I can give you is to remove that door panel and inspect before ordering parts to ensure you order the right parts and can then quickly fix you car
Aby@MIL.SPEC
Aug 19, 2016 09:45 AM
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
