Slight Burning Oil Smell In Cabin After Oil Change
So, two days ago I changed my oil. Everything went fine. Filled it up to the full line like usual. Then ran it for 5 minutes and checked it again. Oil level looked fine. The last two days while driving to school, I noticed a very slight burning oil smell coming out of the vents in my car. I only smell it when I am a stop light for over 5-10 seconds. The other thing is it only seems to show up if the engine is hot. Now I will say it was windy when I was changing oil, and I did spill a few drops down by the fill cap when changing the oil. Could this small amount of oil make it smell? I don't see any smoke, and when I get out of my car and walk around I don't smell anything. I am going crazy over this. PCV going bad? Value seal? Or just some spilled oil. Your thoughts are appreciated.
Burnt oil will only smell through the exhaust. Chances are it's the spilt oil that's cooking and smelling. Wait a few days and see if it goes away, if not, look closer, maybe the valve cover gasket leaks. If none of this works, pull your spark plugs. The seals there tend to break down and leak.
my best bet (if it's not the spilt oil) is that it's leaking through your plugs? when did you last service your plugs?
you can also try checking your cabin filter and see if there's any oil on it?
just a few thoughts.
cheers bro
I changed my plugs around 58K. I am at 78K now. I am starting to think it is the PCV valve or the oil fill cap. Today when I popped the hood there was a small line of oil from the fill cap down the valve cover onto the block. If the pcv valve is bad would it cause extra pressure? Making it come out of the fill cap?
Yea if your PCV is clogged or simply not opening then you will have an imbalance of pressure in your engine, and that pressure could cause leaks elsewhere as something has to give.
We are pretty sure this is what recently happened to my brother's Eclipse. His PCV hadnt been circulating or freeing up pressure and has either caused his head gasket to blow or his head to crack. Compression tests revealed that pressure from cylinders 2 and 4 is being thrown back and forth at each other. And his engine was totally covered in oil. Looked like it was being forced from every possible crack it was bad...
So check your PCV make sure its clear of obstruction and working. id also start checking the valve cover gaskets just to be sure. If it is the PCV you dont want it going unchecked for too long like my brother did...
On your oil cap, check to make sure the screw is tight underneath. My DSM had a loose screw on the filler cap and it would leak oil. As soon as I tightened it, everything was fine.
Thanks for the feed back guys. I am going to stop at autozone after school and pick up a new cap: $6 and a new pcv valve: $4. Then see what happens.
Any pointers for changing the PCV valve? Seems straight forward take the back cover off the valve cover. And just pop the valve off? Are there screws?
Also the other thing after I changed my oil should I check the oil when it is cold or hot? If i check it when it is cold (sitting over night) it is about on the full line. If I check it right after running it is about a quater inch over the full line. Is this normal? Am I overfilled? I have heard of people running half - full quater over the full line for racing and such.
crank case vents to the intake as well...i would check if it's pissing out the cap, or just seeping, the seal on the cap could just be bad...
the pcv valve is just a check valve, one way street...because it vents to the intake manifold which experiences positive AND negative (vacuum) pressure...
