importance of wheel weights?
Someone weighed the stock rims on this site - it was 23 pounds. The lightest production rims I've seen are in the 13-15 pound range (I think a 15" buddyclub weighs around that). OZ Superleggera (means superlite) weigh about 16-17 pounds - for reference.
23 is a pretty good weight for stockers. dropping 6lb per wheel would be nice.
or....
http://store.miataparts.org/koseik1ts.html
drop 18lbs =] should have a similar effect as having a new flywheel.
or....
Originally Posted by captain150
I read that on this site. Maybe it was 20-30lbs? I know it was much heavier than an aftermarket wheel. I also know an RSX rim is in the 30s, horsepower TV (or some other show) mentioned this.
Lighter wheels will not give you hp to the wheels...ever. It's the same principle behind a light weight fly wheel...decreasing the rotational mass, hence increasing the revolutions per given time. You'll learn this in any engineering class when dicussing torque and horsepower.
hi everyone
just one quick thought if you do decrease your wheel size and go to a larger tire hight to to smaller wheel size you are getting more flex in the tire walls so your handleing would go down some just a thought if i wrong please let me know.
You want low profile (short sidewall) for good handling. High profile (tires on SUVs, economy cars etc) are bad for cornering, the sidewall bends and the tread loses contact with the road.
Originally Posted by pgmike
however with a larger sidewall you will get better traction for straightline launching
this thread seems kinda dead, but the correct equation is: for every one lb. of un-sprung weight you remove, that equates to removing 8lbs. of sprung weight. and i believe for every one hundred lbs. you remove, that equates to ABOUT .5 seconds off 1/4 mile times. so if you go from 23lb wheels and go to 17lb wheels, thats 6lbs off each corner. add it up and thats 24lbs. of un-sprung weight.......multiply it by eight.......and thats just like removing 192lbs. out of the interior of the car! which would ALMOST equal a tenth off your 1/4 mile.
exagerated and inacurate =) doenst factor the car's power. removing 100 lbs off a RA does much less than losing 100lbs in a scion (100hp). and what do u mean by sprung weight? 2 of our wheels are part of the drive system. 2 are just to keep the back from draging =)
thats why i capitalized ABOUT, so you could see that i put an emphasis on ABOUT. and sprung weight is anything being supported by the springs. and i was gonna mention something about the fact that these are only fwd vehicles, so i dont know if you could only count the weight loss off the front wheels. but i believe lighter shocks and struts will have a similar effect as lighter wheels, so i dunno? and i noticed earlier you said youd never seen 11lb wheels. i have 11lb wheels.
To the original poster: If you get wheels that are too light, they'll probably also be prone to breakage from daily abuse. Potholes, curbs, etc.. The highways around Chicago *suck*, and I try to avoid the holes, but you can't always see them. I've bent several stock DSM wheels in Chicago in the last 6 years. One of my friends broke one of his lightweight wheels on his Maxima.
breaking lightweight wheels is more of an issue with wheels that allow for a very short sidewall, so the rim gets more of the force than than with a larger sidewall. so if you get a 15 or 16inch wheel, you wouldnt have to worry about that as much.
