Wheel Spacers???
Wheel Spacers???
Are these just a bad idea? I read somewhere that you can put up to 1/4" thick slip-on wheel spacers without getting longer studs etc.
I'm obviously concerned about safety and ride quality... What do you think?
http://cgi.ebay.com/ebaymotors/Wheel...spagenameZWDVW
hey,
I've read up on spacers quite a bit because I wanted to put on some 5mm spacers for daily driving. Now here is the deal. These spacers you mention are generic and are meant to fit any 5 bolt application. the Hub centre is hug and will not centre your wheel during installation. This can cause unwanted vibrations (feels like an unbalanced tire) and there is a slight safety concern. The RA has a hub size of 67.1, when you purchase wheels they are supposed to provide HUB CENTRIC rings. These rings ensure that the wheel is properly centered and that the HUB is actually carrying the weight of the vehicle. When the hub size does not match, all the vehicles weight is on the studs. Studs are meant to hold the wheel from moving side to side, not from moving up and down. My suggestion. If you are going with spacers, you should get them with the proper hub size and also longer studs. THis is the safest way and will not be a safety concern.
Originally Posted by mojambo
hey,
UncleXSO
26
May 19, 2010 03:04 PM
Evo_Someday
10
Jul 28, 2008 12:11 PM
nubby
Mar 7, 2006 11:19 AM
xtnct
Jan 11, 2004 12:40 PM
